1956 model 60
Mike Dunlap
05-23-2007 19:14:39
I have just finished a complete restoration of my model 60. Engine was completely rebuilt along with carburetor. My question is that when the engine is idling it runs smoothly. When it is accelerated to any higher rpm, the engine runs erratic and throttles up and down. when the engine is 1/4 choked the rpms smooth out. What could be causing this to operate in this manner, and what would be the first thing to check?
thanks, mike
Jim Marlett
05-25-2007 17:29:44
 Re: 1956 model 60 in reply to Mike Dunlap, 05-23-2007 19:14:39
Sounds like a stikey float to me
Jeff Oliver
05-23-2007 20:01:41
I would richen it a little on the high idle side. Sounds like your fine for low idle but it is starving at higher RPM's.I am assuming that the carb was rebuilt/cleaned also but there could still be a little trash in it as well.
F-I-T
05-23-2007 20:01:14
Needing choke to run at fast idle generally means you still have a passage blocked or partially occluded.
