630 PISTON HELP
MJN in OH
05-23-2007 14:49:00
I have a 630 with a standard bore with high altitude pistons in it. It looks like somebody did a poor hone job on it at one time. It ran good till I tore it apart though. I did not do a compression test on it though. So would hurt to keep using these high altitude pistons in Ohio. I was going to pull them out and take a good look at the rings and pistons and bore. If I do decide to bore it out to the next size whom should I get piston and ring assemblies from? Deere? Aftermarket? or anybody elese. Thank You for your help.
Mike M
05-24-2007 05:52:41
 Re: 630 PISTON HELP in reply to MJN in OH, 05-23-2007 14:49:00
In Ohio you should be able to run those pistons as I have heard of others doing it. You really NEED to inspect the TOP ring groove for extra wear as I've seen alot of those with broken top rings. They wear then twist and break,but if you are to this point it is usually past time to be rebored.
buickanddeere
05-23-2007 21:06:40
I the ring lands are good, the skirts not scored & the pins ok. Sleeve the block and heep the high alt. You will notice a loss of power if going back to standard compression.
Earl-IL
05-23-2007 19:52:41
I have had good luck with Jerry Hinrich's pistons.Made in USA Original OE duplicate. 815-778-1900 or 815-499-6580
