4840 remote hydraulic leaks
Howard H.
05-22-2007 20:15:01
Also, I've been wondering what exactly tends to wear out when the remote connections start leaking (in this case on a 4840 JD).
I've replaced the O-ring/plastic seal several times in the housing and can't really tell it's making a difference any more.
Do the hose tips wear out? Or is it the butterfly in the housing? Or something else?
Thanks,
Howard
K.B.-826
05-23-2007 17:03:10
 Re: 4840 remote hydraulic leaks in reply to Howard H., 05-22-2007 20:15:01
Yep, new hose tips could help.
Hose tips
05-23-2007 09:33:05
They can wear grooves after a period of time and cut the o-rings etc. Have you removed the complete assembly from the S.C.V. and rebuilt the complete valve,front to back? Which O-ring kit are you using? Just some ideas.
