70 Muffler
Howard H.
05-22-2007 20:12:26
Hi -
I've got a 70 LP JD with a rusted off muffler.
I've seen the oval style and the pipe style - just wondering which is more "authentic" and/or any pros or cons between either.
What is the difference between the $24 and $58 mufflers being offered on Ebay? A real difference? Or just price?
Thanks for any advice,
Howard
buickanddeere
05-23-2007 13:47:32
 Re: 70 Muffler in reply to Howard H., 05-22-2007 20:12:26
It's in print from Mother Deere where the oval silencer muffler is a retro fit back to the 1st numbered & 20 series. The oval muffler is 100% kosher & John Deere legal. The real Deere muffler is easier on the ears and lasts for decades. Anybody that complains about an oval muffler on your 70 also needs an oval muffler inserted where it's needed.
F-I-T
05-23-2007 15:26:40
 Re: 70 Muffler in reply to buickanddeere, 05-23-2007 13:47:32
You know Glenn, I hear you there as the oval was a posted replacement part for a 70, but if you want to restore one to how it left the factory, an oval muffler would not have been on the list, nor would a yellow seat cushion, etc. An approved for retrofit part is certainly different than a factory as intalled part, don't you think?
Frank
buickanddeere
05-23-2007 21:14:50
 Re: 70 Muffler in reply to F-I-T, 05-23-2007 15:26:40
I agree the oval isn't as per out the factory door as new. When the piece is an improvement, has a JD part number and book says go ahead and use it.I'm tempted to make the update. When working on a 70 diesel. One can go from a 10mm pump to 13mm, five to six hole shallow angle injectors, deep/narrow dish pistons and the 730 no injector tube heads with improved flow v.s the 70 heads. I wouldn't feel too guilty about those upgrades too.
F-I-T
05-24-2007 07:58:22
 Re: 70 Muffler in reply to buickanddeere, 05-23-2007 21:14:50
I understand. It's just that Howard asked which would be more "authentic", and if he meant the day she came out the factory door, it would have been the straight muffler. Tires are another upgrade that takes place over the years. The factory tires always seeme to be on the narrow side. Glenn, by your definition, electric start components would almost fit that argument, too..... :>0
buickanddeere
05-24-2007 08:34:23
 Re: 70 Muffler in reply to F-I-T, 05-24-2007 07:58:22
Ouch..... ...
F-I-T
05-24-2007 12:57:40
 Re: 70 Muffler in reply to buickanddeere, 05-24-2007 08:34:23
I thought you'd like that one! :) I just couldn't resist it! How's that busted limb doing?
buickanddeere
05-24-2007 20:44:08
 Re: 70 Muffler in reply to F-I-T, 05-24-2007 12:57:40
Ouch reguarding the leg too. Minor infection after the staples were removed. However taking care of it early saved having to take IV antibiotics. The air cast has to padded perfectly, the components aligned & the velco fastened at the correct tension. Then the straps must be tensioned properly and the air prssure has to be correct on both sides. Or tender & sore/pressure sore spots develop. I couldn't imagine the horrible time in a full plater cast for months. I did too much yesterday and today opening the pool, repairing equipment and watering 800+ trees. The kids make certain it's more work to oversee & threaten them to do chores. Then it would be for myself to just go and do the chores/work myself. I was thinking afterwards re. the electric start conversion. Mother Deere never did offer a "Conversion kit" in the accessory book. She certainly did with the mufflers, 1000rpm ptos & air stacks etc.
F-I-T
05-25-2007 04:50:16
 Re: 70 Muffler in reply to buickanddeere, 05-24-2007 20:44:08
Well, glad to hear you're coming around. I know it is easy to say, but tough to do, but take it as easy as you need to. An old doctor friend of mine always says of post surgery, "You feel better than you are!"
Bobl1958
05-23-2007 08:06:53
I like the oval mufflers myself. If you can afford the extra, the JD muffler has more baffeling inside, and to me has a lot better sound. The aftermarket mufflers have a louder sound, and it seems to have somewhat of a pinging sound to it. Round would be correct, but many were changed after burn-out to the oval for the quietness. I had an aftermarket oval on my 70 diesel and just changed it to a JD oval. No comparison in my books, but JD was $90+. Bob
WeirdDeere
05-23-2007 10:09:59
 Re: 70 Muffler in reply to Bobl1958, 05-23-2007 08:06:53
I wish I had seen this post before getting the aftermarket oval. It is a LITTLE quieter than the factory straight muffler, but not by much.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Jim/Iowa
05-23-2007 06:41:53
The oval "silencer" muffler was introduced with the 730 in 1958, at least two years after the last 70 was made. However, the oval muffler will fit, and may even be in a later edition of the 70 partss catalog as a "substitute" part.
For "Authentic" looks, the "pipe" style is correct. Just like with whether or not you should have yellow seat cushions or use decals which proclaim your tractor has "CUSTOM POWRTROL"
it is after all, your tractor!
wilamayb
05-22-2007 20:17:15
Here is a discussion we had on the topic a couple days ago.
