#227 Mower
Robbywsurface
05-22-2007 19:33:05
I purchased a package deal from a fellow and got a #227 Mower. The tag said made in Canada Serial #001. The old mower is in good shape not even wore out underneath. Has anyone seen one of these sell lately? I am trying to determine what to price it at and if the serial number makes it worth anymore. I got it with a 1951 A witha #45 loader. Thanks,
Robby
Glen in TX
05-24-2007 12:11:44
 Re: #227 Mower in reply to Robbywsurface, 05-22-2007 19:33:05
I hope you haven't bet the farm yet that it's serial no. 001 ? Read the tag again and you'll probably see it says "series" 001. JD didn't put serial numbers on many implements only series numbers and you could might find series 001 on thousands of 227 rotary cutters or at least that's what you will find on many many other models of rotary cutter or shredders or mowers or whatever implement. Sorry to burst the bubble. If they made more than one series the series number is important many times though for getting replacement parts. JD used series or type numbers on many machines and engines in case changes or updates were made later. Your 227 is covered in OMW21323 operators manual where you will probably find a place inside cover to record the series number. Also covered in PC909 parts catalog. JD publications 1-800-522-7448 or http://techpubs.deere.com The parts catalog may be online yet as I didn't check?
robbywsurface
05-24-2007 20:36:57
 Re: #227 Mower in reply to Glen in TX, 05-24-2007 12:11:44
Thank you, whats one like this in good shape worth? $350-$500?
Glen in TX
05-27-2007 09:47:51
 Re: #227 Mower in reply to robbywsurface, 05-24-2007 20:36:57
I'm not familiar with what size that 227 is but anytime you get up to $500 or more and it needs much to fix it start looking at a better one or new one. You should be able to tell looking at most of it but check gear box and oil condition too for idea on how well it was taken care of.
