730 clutch lever pin
bigblock
05-22-2007 19:08:47
I need to replace the pin in the clutch lever but I can't get it out.Tapping with a hammer don't work,and neither does beating it with a big hammer.So I quit before it broke.I thought I was a pro bolt getter outter,but this one prooved me wrong.Any ideas?
bigblock
05-23-2007 17:07:01
 Re: 730 clutch lever pin in reply to bigblock, 05-22-2007 19:08:47
LOL yeah I didn't want it busted,parts for that thing are hard to pay for.C clamp huh.I'll try that.Reckon a propane torch will do it?
bigblock
05-23-2007 18:26:59
 Re: 730 clutch lever pin in reply to bigblock, 05-23-2007 17:07:01
Well I got it out.I forgot about a ball joint press I have.Works great even with a low temp propane torch.Didn't even burn the paint.
JDGMC
05-23-2007 16:35:40
I got mine out just like Frank states. A couple of extra steps I took was to cut off the excess with a metal reciprocating saw and the applied propane torch heat to the casting whill tightening the very large C clamp with a large socket behind it. Some light taps of the hammer and it came right out. A friend bored the clutch handle hole and inserted a oilite bushing that fit the new stud and its just like new now. Now if I could just get the rest of the tractor finished.,
F-I-T
05-22-2007 19:53:21
A deep socket and a large C-clamp works well. Mike A. on here sells a nice little plate pusher that will drive them out as well. Good thing you stopped. There are a ton of broken first reduction covers with nickel weld on them because of over-anxious-clutch-pivot-bolt-tried-to-get-outers-but failed-in-the process-people.
