Center Line on JD 70 seat????????
cat988
05-22-2007 15:39:14
does anyone have a reason why john deere puts a center line on the battery box of JD 70 and others????? ????? ????? ?????
cat988
05-22-2007 16:15:45
 Re: Center Line on JD 70 seat???????? in reply to cat988, 05-22-2007 15:39:14
Thanks Boys for the info!!!!! !!!
F-I-T
05-22-2007 15:45:46
So you could hook your tape measure in the CL notch and hold the tape with one hand and push down on the flywheel wrench on the pinion bolt with the other. If your arms were long enough, you could set the tread width without a helper.
Frank
jhill52
05-22-2007 15:43:28
So you can set your wheel spacing correctly for plowing , cultivating etc.
