2940 Hydraulics and more
JGCLimited
05-22-2007 09:31:18
I have read some discussions that sound similar, but am hoping for some more specific feedback. A quick summary of symptons:
- fast drip oil leak to the left of the I-II-R gear selector, about 2 or 3 inches left of the boot - 4-8 gear wont" stay in place if in reverse (can"t hold it either). You can hold it in gear if in 4, barely, and pretty easy if you want 8 (maybe different problem) - acts like it"s out of fluid when it"s not. Problem begins at start-up... warm or cold
- I have a 265 loader on the tractor, if the hi-lo shifter is in the bunny position (yes, i know it"s hi, but when else can I say "bunny" when talking about a tractor?) the loader will not move up, and the bucket won"t move in any direction. Steering i s also gone. If "lo" is selected, things work much better, but you can still tell it"s not exactly right. - The oil leak is intermittent. I can only see it after I drive over an area and see the fluid on the ground. I can"t see it from the seat, and when the tractor is stopped the hi/lo range selector moves to a spot somewhere in the middle, causing a sick noise if you try to move without setting it.
- the left gear selector wont" come out of I range if there is any load on the tranny. Works fine in R and II.
Any ideas?
I have a service manual, I just would like to know where to begin (transmission problem or hydraulic problem or owner moron problem).
Thanks!
