JD 50 ?
Clint Barnhart
05-21-2007 18:44:46
What weight of oil is used in the housing behind the fan belt pulley, with the pipe plug on top. Sorry about the previous mix up question!
Thanks
John Van Valkenburgh
05-22-2007 18:37:59
 Re: JD 50 ? in reply to Clint Barnhart, 05-21-2007 18:44:46
Frank (FIT) gave the answer I would have. Frank is usually right, more often than I am at any rate.
While you are at it don't forget,
Lube the generator. It has a little oil cup on the back.
Lube both brake spindles. Both have little oil cups.
Both brakes also have a zerk (grease) fitting that gets chassis grease.
The power-trol rockhaft has two grease fittings.
Don't forget to grease both front wheels, along with the Roll-o-matic front end (if equipped).
All the little throttle and choke linkages would also benefit from a drop or two of oil.
That little housing behind the fan belt pulley has a shaft in it that runs back to the governor housing on the engine. It does not take much grease.
Best of luck,
John
1953 Model 50
dds-inc
05-21-2007 18:59:17
uhm...is it power steering? If not, then you just put a grease zerk and pump grease in it.
F-I-T
05-21-2007 18:58:03
It is grease, not oil.
Do you have a manual for this tractor? It will tell you how often to lube that bearing, and what to lube it with, but it is not often, and it does not take much grease.
You can take out the plug, insert a zerk, and put just a few shots of general purpose grease in there. Then take out the zerk, replace the plug, so the next guy doesn't grease it daily like some people do.
