4430 fuel usage
Lincoln
05-21-2007 16:48:46
How much fuel can I expect to burn in a 4430 when using it for mowing hay and other light jobs? Is it compareable to a 4230 or 4020. Thanks
DSK
05-22-2007 15:51:27
 Re: 4430 fuel usage in reply to Lincoln, 05-21-2007 16:48:46
The 4430 was not fuel efficient from new and all of them I knew of took 7 1/2 gallons an hour just making fence. I owned a 4430, 4440 & a 4450 and all of them loved the fuel barrel. You can expect to run that 7 1/2-9 gallons an hour through it just cutting hay. A 4230 wouldn't be a whole lot better. A 4020 would do the job for under 6 GPH, but the comfort of the later tractors will outweigh the extra fuel use. Any one who has cut hay on an open station tractor knows what I mean.
msb
05-21-2007 20:43:33
Pump settings shouldn't matter if the governor doesn't call for more fuel, the injection pump will only put out enough fuel to satisfy the throttle setting. The difference is one of tractor weight and differences in the many different pariscitic(sp?) loads of the different tractors and engines involved. Even at wide open throttle the pump will only inject enough fuel to maintain the engine speed and that can vary greatly depending upon the load on the engine. All things being equal,a turbocharged engine can conceievebly use less fuel on a light load verses a nauturally aspirated engine due to greater efficiency from the turbocharged engine.
Stonecreek
05-22-2007 14:43:33
 Re: 4430 fuel usage in reply to msb, 05-21-2007 20:43:33
The comment on parasitic loads is rings true. However, at lesser load the turbocharger is itself a parasitic load and reduces the efficiency of the engine. At higher HP output the turbo boosts efficiency.
dds-inc
05-21-2007 19:10:36
Make sure your pump isn't turned up. You will be wasting horsepower and fuel just cutting hay.
Stonecreek
05-21-2007 18:30:32
It will be a bit more than a 4230 and somewhat more than a 4020 for a medium-light load. The 4020 has less weight to drag around and is set to pump a little less fuel. The 4230 is about the same mass as the 4430, but it is set to pump a little less fuel. The difference between the 4230 and 4430 is much more noticeable at near-maximum loads, but then you're doing more with the 4430, so the difference is somewhat offset.
Stonecreek
05-21-2007 18:34:26
 Re: 4430 fuel usage in reply to Stonecreek, 05-21-2007 18:30:32
I should add that the fuel consumption is highly dependent on the condition and adjustment of the fuel system of any older tractor. You could conceivably have a 4020 burning much more than a 4430 under the same load, depending on those factors. But on average, the higher horsepower tractor will burn a bit more fuel for the same less-than-fully-loaded job.
