How to thread twine into a John Deere 24T baler
Matt Evans
05-21-2007 11:56:54
I recently had a 24T baler given to me. Baler is in excellent condition and i would like to start using the baler to supply my horse feeding needs. I have 2 brand new rolls of twine which were also given to me but i don't have a clue how to route the twine through the baler. Could someone tell me how or possibly send me a diagram ? Thanks, Matt
Iowa Farm Boy
05-24-2007 08:08:05
 Re: How to thread twine into a John Deere 24T bale in reply to Matt Evans, 05-21-2007 11:56:54
I bought a Manual on CDRom several years ago for my 214T, and love it. Just print off the pages you need and head to the barn. If they get greasy or dirty, no problem. It is a very detailed and will come in handy.
matt evans
05-22-2007 05:38:23
Thanks to all the comments, very helpful. Matt
TimS in Mo
05-21-2007 20:18:28
I haven't done this on a 24 T...but on the 14T..you take the twine up thru the lid of the twine box, over thru the twine tensioner, down thru the ceramic piece toward the back of the bale chamber, forward and up under the needles thru a ceramic on each side, then thru the eye of the needle from front towards the back, pull the twine out towards the rear and tie it off to the bale tension adjusting crank....
Then you can just start the pto up and trip the tie start lever, which is activated when your bale length wheel had roated far enough to trip the tieing normally, the twine should feed up automatically and be grabbed by the twine disc at that point and be held in place ready to bale.
I do recommend a manual, it has pictures of different tieing problems and recomendations on how to adjust the knotters to fix them, it also discusses all the different maintenance items needed, grease zerks you would otherwise never find, etc.
55 50
05-21-2007 17:24:23
I agree with Bob that there may be a decal somewhere to show this. If not, please do what 95CS said and get a manual. It's not at all easy to try to explain twine threading without some diagrams and writing to accompany them. AND all the other info in the manual will be needed at some point anyway.
Bob
05-21-2007 14:37:13
IIRC, there's a decal diagram, probably inside the lid of the twine box.
95CS
05-21-2007 12:54:59
Perhaps someone will send you what you need, but call 800-522-7448 and spend 30 bucks to get yourself an Operator's Manual. It will tell you what you need to know, and will tell you how best to care for your baler. It will repay its cost many times over.
