52 B Power Lift Question
ddk114
05-21-2007 07:34:06
I have the stomp pedal ahead of the seat. Is there any other use for this lift other than cultivators. It would be nice to be able to use a hydraulic cylinder. I was used to PowerTrol.
RonB in CO
05-21-2007 15:00:48
 Re: 52 B Power Lift Question in reply to ddk114, 05-21-2007 07:34:06
Watch for spring #42 in the exploded view to possibly fall on the floor or ground.
Mike M
05-21-2007 07:47:54
You can just swap out the hyd. box from a power-trol and your all set.
ddk114
05-21-2007 10:53:02
 Re: 52 B Power Lift Question in reply to Mike M, 05-21-2007 07:47:54
I have the whole rear cover assembly off of an A. Is there any any parts or gaskets I will need?
F-I-T
05-21-2007 11:19:51
 Re: 52 B Power Lift Question in reply to ddk114, 05-21-2007 10:53:02
third party image
You only need one gasket, and your dealer probably stocks it. It's the same gasket that is used for either the basic Powr-Lift box or the Powr-Trol box. You don't have to remove your rear coaver at all.
Frank
