4020 leaks hydraulic oil
Thomas Harvey
05-21-2007 07:03:02
I have read the posts here but don't seem to see what I want. I just got a 4020 D and there was a small drip of oil under the tractor. Now its leaking too much it is the shaft that sticks out both sides that holds the frame for the drawbar. I know I need to get service manual, but my guestion is can this be fixed from the outside or must the cover come of the tranny. My brother will fix it for me. It is leaking on the right side and on the left side it is damp but not leaking but the little end piece is missing the round end.. THanks for any info
Glen in TX
05-21-2007 11:33:01
 Re: 4020 leaks hydraulic oil in reply to Thomas Harvey, 05-21-2007 07:03:02
If the shaft or anything looks even a tad worn or has marks on it replace or it will leak again. Get all the slack you can out it in the wishbone holes too and shim side play with shims available from JD. Boling sells the aftermaket seals and bushings. I've had good luck with both. Again getting slack and wear out is key thing no matter which seals you use. http://www.bolingmachine.com/
Tom Harvey
05-23-2007 12:50:23
 Re: 4020 leaks hydraulic oil in reply to Glen in TX, 05-21-2007 11:33:01
thanks everyone for the help I have ordered the parts thru boling to include the shaft
JD@Antique Acres
05-21-2007 08:41:30
Most likely you will need to replace the seals with the updated bushing o-ring type which are available from Deere. But as Gerald mentioned the shaft also needs to be check for wear.
JMS/MN
05-21-2007 08:13:52
No need to remove the tranny cover or rockshaft- all done from below. Drain the oil first, and use a hydraulic jack to support/lower the wishbone if you're working alone.
Gerald J.
05-21-2007 08:06:47
Look up Boling machinery. They sell parts that some believe are better than original Deere parts for that load sensing shaft. Its important to be sure the shaft isn't worn at the seal location, so sometimes it takes more parts than bushings and seals, namely the shaft.
I think Boling has a web page on how to do the job.
There can be a need to adjust the shims on the shaft to minimize side motion of the draft frame for better seal and bushing life.
You will need to set at least one wheel out near the end of the axle to pull the shaft.
Gerald J.
Stonecreek
05-21-2007 07:47:41
The load & depth seals (as some call them) are pretty common items to go bad on the larger Deeres. Replacing them is done from the outside and is within the grasp of a shade tree mechanic. If you don't have access to a technical manual, someone on this board can probably give you reasonably useful direction.
Bob
05-21-2007 07:16:28
Thomas,
Type "load control seals" into the search box at the top of the page.
