F I T -- 60 mower deck question
Nylon
05-21-2007 00:44:59
I have greased the heck outta my spindle bearings. And they always take quite a bit of grease. And they deck has always had a pretty good "roar" when engaged. I talked with the guy who bought deck new and had it before me...about 200 hours of mowing on deck. He said the deck always had that roar. I jiggle the blades and there is just a touch of play...seems just right...operates smooth..no clicking or catches. But even spining it by hand it seems a bit growley? Me being nervous ned am wondering if you have any words of wisdom? Your deck kinda loud when engaged? It doesnt sound like anything is really wrong. The mid pto turns at 1300 rpms so it gets louder with rpm but no bad vibrations at all.
Bearing parts are cheap but having dealer do it is $200. Heard those bearings are a bugger. Would that be $200 well spent if it gets to where I need bearings? Thanks for any info
John
F-I-T
05-21-2007 11:04:30
 Re: F I T -- 60 mower deck question in reply to Nylon, 05-21-2007 00:44:59
>>>I have greased the heck outta my spindle bearings. And they always take quite a bit of grease. And they deck has always had a pretty good "roar" when engaged. I talked with the guy who bought deck new and had it before me...about 200 hours of mowing on deck. He said the deck always had that roar. I jiggle the blades and there is just a touch of play...seems just right...operates smooth..no clicking or catches. But even spining it by hand it seems a bit growley? Me being nervous ned am wondering if you have any words of wisdom? Your deck kinda loud when engaged? It doesnt sound like anything is really wrong. The mid pto turns at 1300 rpms so it gets louder with rpm but no bad vibrations at all. >>>
Yes, IMHO those decks are pretty noisy. After a bearing job, they quiet down some, but they also move a lot of air, so that increases the noise component as well. Idlers whine, too, and you get some noise from the pto shaft. It's not like an all-belt driven 48" deck on a 14hp 214. There just is not much rubber to help dampen the noise.
That said, if you do choose to R&R the bearings, if you did it on the cheap, and only had to install new JD bearings, it would run you about $17 per spindle. There are also two very pricey snap rings in there so if you foul those they're $5.50 each to replace, so that would increase it to $40. The top bushing runs $9. The parts book says there is also a seal, but I do not recall that. Maybe that is special for the 60" deck. Anyway, that's another $6, so you could have between $17 on the low side and $42 on the high. Times three spindles, you get $51 to $126 in parts. I imagine the $200 would cover the bearings only, so it could be more. I always do my own, and I install a new set of blades when I replace the bearings. I bought three brand new spindles on Ebay for $100 (spindles and sheaves included!) last fall, and those will go into my new 72" deck. If you have the ability to remove the sheaves without bending them you should be able to do your own work, though there is a lot to be said for dropping them off on Monday and picking them back upon Thrusday, ready to go.
One thing I like to do on anything of this type of design is to mark the orientation and location of the spindles. I know it should not matter where they reinstall, but if you know which one was in the left hole and which side of it faced forward, and the deck mowed good before you tore it down, why not eliminate that as a variable when you reinstall....one of my quirks learned when bumping mill fixstures around. Scribe the table and you can always go back to where you started.
Frank
buickanddeere
05-21-2007 11:02:23
Too much grease pumped into a bearing is worse than not greasing it at all.
F-I-T
05-21-2007 11:22:46
 Re: F I T -- 60 mower deck question in reply to buickanddeere, 05-21-2007 11:02:23
You really can't overgrease these Glenn. It just vents what it can't hold at the seam of the bottom spindle arbor face and the lower bearing. Sprays all over the underside of the deck, though.
buickanddeere
05-21-2007 11:46:18
 Re: F I T -- 60 mower deck question in reply to F-I-T, 05-21-2007 11:22:46
The bearings are due for a replacement in my son's 110's model 38 danger deck. It luggs the engine and tosses the belt in about 30 seconds or running. At least it won't take very much walking to do it. The bearings are on the "round to it" bench.
F-I-T
05-21-2007 12:20:50
 Re: F I T -- 60 mower deck question in reply to buickanddeere, 05-21-2007 11:46:18
Well, if you never had to replace deck bearings, you didn't have enough land, right?
Years back, when I was a young materials manager, also in charge of Purchasing, our local bearing supplier was Motion Industries. Their rep talked me into using an upgraded bearing in my 214 48" deck instead of the stock number. The cost was only a couple bucks more per bearing. After 6 years of two acres a week, I sold the tractor and it had not had required any bearing replacement. Those were sealed bearings, so I would have to say that the extra money was worth it. Might want to check into those.
Nylon
05-21-2007 17:19:21
 Re: F I T -- 60 mower deck question in reply to F-I-T, 05-21-2007 12:20:50
Thanks for the good info. I think this is a case of drop it off pick it up. Trouble is none of these guys have 1/4 what your knowledge base is.
I suppose that 1300 rpms makes that grease melt pretty quick. I have squirted it in till I see it comming out the back seals a tad. I imagine that I could just as well put a couple of pumps in there at start of each session and it will heat up and disperse. Rather than fill whole thing up and loose it.
Nylon
05-21-2007 17:24:39
 Re: F I T -- 60 mower deck question in reply to Nylon, 05-21-2007 17:19:21
PS I am no fan of overgreasing. My neigbor overgreases all his loader pins, 3points, plow tailwheel and etc as well as everything else. I get more grease on me helping him do anything than I can believe. Not to mention all the dust and sand and crud sticking to the grease.
