The tire clearance problem seems to be a recurring issue with the -55's and the next newer models. I have made a couple of mods to the linkage that improved it to the point that I'm ok with it. That said, with 955 size turfs on an 855, a hard turn either way will rub the front edge, just enough to keep the paint rubbed off. I have a new deck stamping for the 72" deck that was used on the 4200, and I intend to mod one set of drag links to place the deck as far aft as possible without interfering with the rears, then adjust/modifiy the front yokes, so that I might gain some clearance for turns on the front. If you lengthen the side mid-point drag links, and lengthen the turnbuckles in the front, you can move the deck aft an inch or so to accomplish this, and an inch is a lot. On the 4200 deck that will not lift all the way, have you adjusted the rear two lift links? You can shorten those, so that the slack will be gone before you run out of bellcrank adjustment. That deck should be hanging on those links when it is at mowing level. It sounds like your links are set too long, or you have the incorrect lift links. Maybe block it at the correct height and measure the links you have to determine what general length they should be. Like I said, I have accumulated a couple sets of attaching hardware, and there does seem to be more than one length of lift link. You can easily cut/weld/change those.
