36 BN Front tire Issue
CalJim
05-20-2007 19:22:30
Hello,
Have a 36 BN with the AB 408 Yoke and AA 847
2 piece wheel. When I try to put a 9.00 x 10
tire on it won't fit, it is too tall, the tire
hits the top inside of the yoke. Tire is an
American Farmer with one large rib in center.
Has anyone else encountered this? I will be
contacting Miller Tire tomorrow. I know the
10 is bead width, what does the 9.00 dimension
measure? Thanks to All CalJim
P Browning
05-21-2007 10:31:43
 Re: 36 BN Front tire Issue in reply to CalJim, 05-20-2007 19:22:30
CalJim -- Monday is our shopping day and as we drove by one of the tire places here in town, I remembered one outfit that used to TRUE tires, and by this I mean they would mount the wheel on a machine and while the wheel & tire turned, a small shaving type knife would take rubbber off until the tire was once again ROUND.
If such as outfit exists where you are and you don't need much trimmed off, it just may work out to take such a route. To facilitate mounting of your wheel onto the truing machine, you would need to remove the axle and felt washers -- then go for it. Just another thought! (PatB)
P Browning
05-21-2007 00:51:25
Just thinking aloud here -- it is my assumption that the 9.00 x 10 tire should be okay, but will need to be of the three-rib design to fit the Unstyled BN Yoke & wheel with part numbers you have cited. I think you will find that those with the single rib tend to have a larger overall diameter -- thus giving you interference with the yoke.
Please post back when you find out the bottom line. This one will interest a few folks on the board. (PatB)
hardscrabble
05-20-2007 19:35:25
Nine is the bead width. Ten is the bead diameter.
