1946 JD A power
LDP
05-20-2007 16:45:55
I have been working on a 1946 JD A all fuel (with magneto) trying to get it to run better. I have both cylinders firing but it still does not have the power I think it should. It has 60 to 65 lbs of compression on both sides. If it is running correctly should I be able to stop it with the brakes in 1st gear? I can. I just bought a 1940 Farmall M and I can not stop it with the brakes in 4th gear. Any sugestions or ideas? Thanks!
Mike M
05-20-2007 17:42:35
 Re: 1946 JD A power in reply to LDP, 05-20-2007 16:45:55
Hard to tell about HP without a dyno. RPM setting can make a BIG difference. That model being low compression won't be a power house and JD's have far better brakes than those Farmalls and a good chance that M has an increased HP kit in it. It's been awhile since I last ran my 46 A and even then I doubt I ever tried to bring it to a complete stop in any gear. I did pull a 2 bottom plow very well with it. If your compression gauge is reading right your tractor may be just a little low as I thought 75 psi was more like it should be ?
