410 backhoe need a JD mechanic to look at this
eflynn53
05-20-2007 15:58:22
OK, I have finally gotten it apart. I posted a few times trying to get a mechanic's opinion. 410 with no flow at trans. pump.1)changed fluid 2)started chattering 3)quit(no hyd/no trans) 4)ran with no trans filter to check flow at trans pump-nothing 5)split tractor 6)clutch worn,throw-out bad, next bearing in series bad(slop towards transmission side)...Have not gotten reveresr out yet (I am working in yard/raining like hell)
Anyway, my questions are 1)This aint no small job and I want an opinion on what else do I change assuming clutch was problem? (ie Do I change trans. pump just because??) 2)Can I just change gears for pump and save a few bucks vs. pump assembly?? 3)What is the min. thickness on clutch disk (I have 3/8). If anyone can help the mystery is killing me. Thanks
Roy Suomi
05-21-2007 06:27:38
 Re: 410 backhoe need a JD mechanic to look at this in reply to eflynn53, 05-20-2007 15:58:22
Check for the splines in the clutch disk..They might be gone....Input shaft for splines worn off..Very common problem on older 310-410 machines..Show same characterstics as you said..
matthies
05-20-2007 19:42:16
I hope you checked the sump screen first. Do you have any functions, like steering?
Brian Cotton
07-26-2007 09:18:31
 Re: 410 backhoe need a JD mechanic to look at this in reply to matthies, 05-20-2007 19:42:16
Hi Guys,
I think I may have a similar problem which I can buy or not...
I am considering buying a JD 410 TLB that is apparently in good condition with a new engine except for the fact that the main drive unit / gearbox unit that selects forward and reverse has died - it has marginal reverse drive, nothing forward...I am very good mechanically but TLB drive systems are a new to me.
Can these parts be fixed regardless, are they interchangeable with other brands (with a bit if fiddling) or will I buy a big headache.
I can get the machine for equivalent of $4700 - considering that a brand new Turkish TLB (4x4)costs $53 000 and a working but used JBC / CASE/ other big brand one is from @ 10000 to $20 000
eflynn53
05-21-2007 10:28:19
Checked intake screen, mostly clean except for a piece of thin metal on outside of screen (looked like the foil from a quart of oil) or a slice of bushing. As for clutch splines, they look good, in fact had helluva time seperating. I plan to change clutch disc, throwout bearing and then the next bearing behind the throwout. My big question is the pump. Do I change it just so I don't have to do the job again? The other question is the pump itself. What goes bad? The gears? Can I just change individual parts or does it only come as unit? Any help greatly appreciated.
