JD 2240 PTO functioning
loren owens
05-19-2007 19:16:46
Have a JD 2240 tat i Mow with, has 2800 hrs.
today i noticed when mowing that the PTO was slipping. First i thought it was the mower cluth plates that were slipping but realized it was actually the PTO.
Does anyone know how the independent PTO is designed. would ther be an adjustment i could make to stop the PTO from slipping or do I have a more serious problem internally. If so any idea what the repair entails?
Thanks
buickanddeere
05-20-2007 07:11:57
 Re: JD 2240 PTO functioning in reply to loren owens, 05-19-2007 19:16:46
What kind(s) of oil has been added to the trans/hydraulic system over the years? If the trand pump's intake screen & filter is plugged. Primary low pressure and of course high pressure hydraulics will suffer. I assume tho the high pressure hydraulics still operate? The pto clutch, high/low clutch pack and the intake port of the high pressure pump are the main low pressure loads.
LOREN OWENS
05-20-2007 17:56:27
 Re: JD 2240 PTO functioning in reply to buickanddeere, 05-20-2007 07:11:57
I have exclusivly used JD Hy Gard Tansmission oil and changed the filter for 27 years, i bought it new.
My frontloader bucket works normal, and so does the 3 point hitch.
Its seems to be only the PTO that is slipping.
I am worried that this will be an expensive repair and the tractor will nee to be split open.
thanks for your reply
Tx Jim
05-20-2007 04:05:58
If you have ind. pto it is hydraulically operated. Raise cover over transmission and there are ports to check hyd pressures for pto clutch and brake. I think 175 psi is correct. If pressure is low look for a broken oil tube leading to clutch pack under/behind cover or blown sealing ring in clutdh pack. Over the years several of these tubes were replaced on similiar models at JD dealership I worked for. Tx Jim
Loren Owens
05-20-2007 04:52:40
 Re: JD 2240 PTO functioning in reply to Tx Jim, 05-20-2007 04:05:58
Tx Jim, thanks for your quick reply, I will need to take this to a dealer for repair. If the problem is what you describe can the repair be made without splitting the tractor apart? Do you think a JD dealer would have a flat rate for something like this?
thanks
Tx Jim
05-21-2007 04:59:16
 Re: JD 2240 PTO functioning in reply to Loren Owens, 05-20-2007 04:52:40
If a cracked tube is the problem,it can be R&R without splitting tractor but pto clutch would require a split. It also might be the control valve. First thing to do would be pressure test. JD dealer should have a flat-rate manual for your tractor. Tx Jim
Loren Owens
05-21-2007 05:26:31
 Re: JD 2240 PTO functioning in reply to Tx Jim, 05-21-2007 04:59:16
Tx Jim thanks for your reply, this is very helpful information
