1941 AR restoration help Me!!!
Ryan Wildenberg
05-19-2007 18:26:00
Hi, I am unfimiliar with John Deere tractors and am curios as to how much of a job it is to remove the head from an AR. To my understanding the camshaft is located right by the crank and the push rods run the length of the block into the head. So when I remove the head I will not mess up any timing. Please correct me if I am wrong. I am also wondering how I should clean out the clutch area. Is it safe to spray brake or engine cleaner into the clutch to remove build up? I am also curious if there are any tricks to remove busted off/rusted tight bolts. Any help will be greatly appreciated, thanks
Dominic Centonze
05-20-2007 02:52:05
 Re: 1941 AR restoration help Me!!! in reply to Ryan Wildenberg, 05-19-2007 18:26:00
I have done several AR's and they are one of the easier tractors to do. Very forgiving if you "mess something up". If you encounter any bolts that refuse to turn, don't force them to the point of breaking the head off and leaving the stud still in the cast body of the tractor. THEN they are a pain to take out. I like to heat the stuck nut/bolt to a dull red color. Let it cool for about 30 seconds. It it still doesn't come out repeat procedure. If it still doesn't come out after a few heatings, spray the stuck bolt/nut with either Gibbs, PB Blaster, Kroil or other rust buster. They are not flammable but still wait about 2 minutes before spraying the hot metal. And like Maaark says, heat always works. It has never failed me in over 50 tractors I rebuilt/restored. Good luck!
Maaark
05-19-2007 19:40:12
You wil not screw up the timing by removing the head.removing the head is pretty straight foward. remove the carb, lower radiator hose, valve cover, rocker arms, then 9 head nuts, pull the push rods out, you may have to hold your tongue just right, but they will come out.You may have to use a bar between the water neck and manifold to get the head past the lead washers that are smashed unto the head bolts.There isn't usually much build up on the outside of the clutch, just use compressed air on the outside parts. Heat from a torch outfit works very good on rusted bolts.
