60 live pto getting hot.
Chris Parrish
05-19-2007 13:11:06
Well My '56 model 60 pto is getting hot. I have adjusted it I am wondering if anyone might have a Idea why? Also what oil goes in there. I may have to tear it down maybe I have a bearing trying to do bad I dont know. Just looking for any help before I dive right in Thanks
55 50
05-20-2007 14:29:19
 Re: 60 live pto getting hot. in reply to Chris Parrish, 05-19-2007 13:11:06
By getting hot do you mean so that it smells burned or just that the case is hot to touch?
Just hot to touch should be the normal way. It uses #10 motor oil and since it"s a clutch running in oil it gets hot from normal use. If it"s so hot that things smell burned then there is some real trouble. If it"s disengaged by the lever next to the seat, the input shaft is still turning and the disks are rubbing lightly on each other and that creates heat. That"s also why the manual recommends disengaging the input shaft (small lever near the main transmission shifter) when not in use.
Mike M
05-19-2007 17:46:00
They are to have a thin oil in them. I use JD Hy-Gard as I have it for the newer stuff. A common problem is for the tranny gear lube to mix in there. If this is the case then you will need to remove the whole rockshaft housing to get at those seals.
