3010 PTO Fix
JB in NE
05-19-2007 08:00:19
Looking for some help on how to make the pto in a 3010 full time 540 and avoid potential problems with the pin in there bending or breaking like the 10 series are known for. I'll have this tractor split to replace the clutch and would like to do this while it is apart. Any help is appreciated!
Tx Jim
05-20-2007 04:19:11
 Re: 3010 PTO Fix in reply to JB in NE, 05-19-2007 08:00:19
JB,if you can't find instructions in archives on my idea to eleminate the pins my email is hayman1 at htcomp dot net. I changed several 3010/4010's years ago. Tx Jim
720 Lyle
05-20-2007 03:58:55
If you go back in search area Jim from Texas had a fix for this problem that was rather simple when you had it apart. It is amazing how a very inexpensive pin can cause so much work. If you opt to not go the 540 full time route and replace the pin. Drill holes in the mounting bolts for the stub shaft and wire them so viberation does not loosen them.
Bob
05-19-2007 23:24:59
I've owned, run, or been around quite a few of those tractors in my time, and have NEVER seen a problem first-hand.
Problems that DO occur are almost ALWAYS 'cause folks swap the stub shafts, and tighten 'er down without wiggling the shaft back and forth to make sure the splines on the shift collar are engaged.
If you do it that way, something HAS to break!
