3020 repower
Mike_730
05-19-2007 07:01:54
I plan to repower a 3020 with a 4045 powertech engine. Has anyone done or seen this. I saw another post saying dealers are installing 4045's in this tractor, my dealer was clueless. I have the engine and engine computer will be building my own wire harness.
MSM
05-19-2007 11:36:58
 Re: 3020 repower in reply to Mike_730, 05-19-2007 07:01:54
That's kinda like putting lipstick on a pig isn't it.You would be money ahead just buying a reman engine or completely go through your existing engine.Time you adapt the frame rails,drill the block for the pump stand,find a pump stand,get the bellhousing adapter and all the needed small parts,change the whole dash,change water pump, and maybe the fan shroud,you can buy a reman engine from Deere with a warranty.And the tractor will have some value when finished.
Mike_730
05-19-2007 12:23:33
 Re: 3020 repower in reply to MSM, 05-19-2007 11:36:58
Yes it is somewhat like lipstick on a pig. this "pig" has set apart for over 10 years looking for a used or reman diesel. the tractor is a gas job now so i would need it compleat. I have called JD reman myself for that tractor there is none in stock I would need to send them a core engine. Dad did find and buy a good used gas well it's not so good, cracked block that makes two. I work for a deere construction dealer and got this engine compleat and CHEAP under a grand with less than 300 HRS on it.
MSM
05-19-2007 17:39:05
 Re: 3020 repower in reply to Mike_730, 05-19-2007 12:23:33
Where are you located,there are a couple of yards an Pa that have 3020's for salvage.Otherwise you will need a 2510 pumpstand,a 4030 bellhousing adapter,(if they will work on the new style engine)plus modify the frame to catch the bellhousing bolts. If you have an early model tractor and your engine is turbo'd it won't work.the turbo sits where the remote valves are mounted.I have repowered console models with
239T's and a 276T.It's not too hatefull of a job with an old style engine.
mike_730
05-26-2007 06:50:07
 Re: 3020 repower in reply to MSM, 05-19-2007 17:39:05
I am in up state NY and yes this engine is turbo That can change quick a easy four bolts and two oil lines, bye bye turbo. The computer can be reprogramed to non-turbo specs, there is no difference in the fuel pump only the ECU program
