JD 2440 hydraulics
Brian in Co
05-18-2007 21:45:14
I have a friend that has a 2440 that has a loader and he has been cutting with a 6 foot mower all his fluids are topped off but after about 3 hours of running the mower deck starts to bob up and down It gets worse at lower rpms and also the loader becomes jerky at that time also if used. If you shut down and let it cool off for over 6 hours it works well until it gets hot again( about 3 hours)Just wondering is this an issue that should be fixed prior to continuing to run the tractor( Yes I know that all issues should be resolved asap) but the tractor service guys are busy as can be getting all the big farmers tractors going for hay season Any help would be appreciated My knowledge runs in the IH and Ford catagories and I dont know much about the greenies. Could the tractor still be run cutting with the deck without damaging the pto drive??? He has about 40 acres left to cut. Thanks for any info in advance
flying belgian
05-19-2007 18:17:41
 Re: JD 2440 hydraulics in reply to Brian in Co, 05-18-2007 21:45:14
I have a 2440 and never had that problem. I wonder if the filter is colapsing when the oil gets warm.
Brian in co
05-20-2007 08:28:26
 Re: JD 2440 hydraulics in reply to flying belgian, 05-19-2007 18:17:41
Good question I forget to start with the simple things! Thanks
JGCLimited
05-21-2007 11:57:48
 Re: JD 2440 hydraulics in reply to Brian in co, 05-20-2007 08:28:26
Can you tell if the fluid itself is getting overly hot? Hydraulic fluid contains a lot of air (as much as 15%) and when heated, it can come out. Things like clogged oil coolers (easily clogged by debris between it and the radiator) and oil pumps caked with gunk can prevent adequate cooling.
