I think you will be disappointed. The tank size is such that you will spray and wait for the tank to refill a lot. This will waste a ton of time, and cause you to try to spray too heavy, too few coats. You might try the most CFM friendly gun you can find, but my experience has been that a 25 gal/5 hp is the minimum for comfortable operation. That said, I have painted old Synthol paint from the '60's, which is all that JD or Rustoleum paint is today, with a 1/2 hp compressor, and got decent results, but it took me some time. Those were also the days of no hardener on tractors, so picking up a wet edge blend line after frequent starts and stops wasn't as big a problem. IF YOU INTEND TO USE ANY HARDENER, READ PREVIOUS POSTS ABOUT THE DANGERS OF HANDLING AND USING ANY PRODUCT CONTAINING CYANOACRYLATES. THIS IS SERIOUS STUFF. It seems that lately the use of hardeners has become pretty ordinary and sometimes discussed in a lackadaisical manner not befitting the importance of using proper safety gear. Be careful, lest you get that tough, hardened, shiny finish in your lungs, or better yet, get the sensitivity to the iso-cyanates. Otherwise, it could be a banner year for your local university medical center, not to mention your neighborhood respiratory therapist, and eventually, undertaker. Frank
