212 lost spark?
richlag
05-18-2007 19:58:42
I recently put a new battery and ignition switch on my Dad"s 212 and it ran great for about 5 hours. Now I"ve lost spark. I"ve tried to clean any corrosion off any connectors I could find. Anyone have any ideas?
F-I-T
05-18-2007 20:32:30
 Re: 212 lost spark? in reply to richlag, 05-18-2007 19:58:42
Rixh:
As a 214 owner/user for many years, if you were handling the wires while installing the new switch, which you would have had to do, you might have distrurbed one wire near ready to fall off, or brittle and so it fell apart five hours later.
Switch on, check that you have 12 volt power at the input to the points. I bet you just have a loose or broken connection at the new switch. Now just a note, 15 years ago, JD even offered a "kit" of several higher grade stak-on connectors to use to replace the old wiring harness connectors, as they carry full current and over time they can get annealed and they get loose, draw more power to compensate for the increased resistance, and hence they can get red hot. Quite few 200 series burned to death because of that, or at a minimum, fried a harness, so if I were you, I'd check that out.
You lost your or you have a bad safety seat switch/pto circuit. That should only show up when you hit the pto though, if my old mind can be depended upon. I might be off base there. My bet is a simple wire fell off the switch and has killed the coil input. Try a jumper lead to the coil + side if you want to find out fast, because if it cranks, it should fire with power supplied directly to the coil primary input. If it does run, you have problems from the battery to the switch (do the lights work?), or from the switch to the points.
Frank
