60 series exhaust on 55 series?
TIMAR
05-18-2007 19:38:04
Amyone tried to put the side exhaust from a 60 series JD on a 55 series or just manufacture one themselves?
G/MAN
05-19-2007 21:42:19
 Re: 60 series exhaust on 55 series? in reply to TIMAR, 05-18-2007 19:38:04
If you're talking 55-series to 60-series, you must be talking about a large-frame row-crop - 4555 to 4560 etc, not a 4wd. That's a considerably different scenario than a 4wd. I doubt there is a kit available, and there are considerable differences between the two. Start at the exhaust manifold and work from there as that's where the differences start. Then the turbocharger - it's also different. And the engine oil-filter base and various lube system parts and pieces - 60-series tractors have the vertical filter, not the horizontal unit found on the 55s. And the ether-assist system. And the air intake system and air filter assembly. And the battery boxes. And the RH cab fender, and of course the LH fender assembly if you want them to match. The muffler alone for a 4960 is about $500 new from Deere. Figure $5000 minimum parts and labor to do the swap, maybe much more. And then you won't be able to open the small service door - the whole thing is removed for access on a 60-series. And of course you'll have two gaping holes in your 55-series hood. A new or decent used 60-series hood won't be cheap. It can be done, but I've been asked that specific question before by a guy that was seriously interested in doing the same thing to his 4555 and had the cash to do it, and he quickly decided against it.
Ron in N.e. COLO
05-19-2007 11:05:06
There is a firm in Kansas or Oklahoma who builds a retrofit kit to do this. I have a neighbor who converted an 8440 to the side exhaust much like the 8450. If interested, I will find out the name of the firm. Thanks, Ron
rexhellwig
05-19-2007 09:14:50
If you suceeed in this, I predict you'll regret it.
You might first ask yourself, "What do I hope to gain?"
Servicability? This is a huge step in the other direction. Visibility? Well then, the air stack will also have to be moved, since it is also in direct line of sight with the original muffler. More problems remain. The joint where the cab door closes is also in this line. You won't be relocating that.
Pretty smart, those old engineers back in the early seventies. Three obstacles to interfere with the operator's vision and they managed to line them up so as to only become one.
Not all "updates" are actually "improvements".
G/MAN
05-19-2007 21:48:00
 Re: 60 series exhaust on 55 series? in reply to rexhellwig, 05-19-2007 09:14:50
Serviceability is an objective question, and depends on what you're servicing. Some jobs are easier on a 55, some are easier on a 60. I've worked on dozens of each, and I've spent a fair amount of time in them in the field. When it comes to the exhaust system - wasting any time on a 60-series trying to remove it piece by piece is just that - a waste of time, unless you have to replace a part, and I've only ever replaced one 60-series muffler and a handful of the stack extensions. I've seen 4960s with 10,000+ hours and the main exhaust pipe was original - they built them well. If the exhaust is in the way, remove the whole system in one chunk. Remove the heat shield and rear turbo clamp, unbolt if from the mount at the RH cab mount and the bolt from the side of the cylinder head, remove the headlight bezel and the nut and washer from the upper mount and take the whole works off in one piece. It can take a lot longer to remove the plain old muffler on a 55-series.
rexhellwig
05-20-2007 06:51:57
 Re: 60 series exhaust on 55 series? in reply to G/MAN, 05-19-2007 21:48:00
For me, getting those screws out of the RH bezel on a 60 eats as much time as a 55 muffler R&R.{The holes fill with dirt, draw moisture, and rusts away the screw heads} On a 55, Routine jobs like valve adjustments and injector testing don"t even require muffler removal. Not so on a 60.
