Dropped the Carb and broke it
Wyman 36A
05-18-2007 15:56:45
After finally getting the nozzel out of the carb, from my 1936 A, my son dropped it on the floor and broke one of the ears with the bolt hole in it off. We have rebuilt everything else on the carb. and would like to use it. Could this be brazed back on or does someone know of a source to buy just this part of the carb body? Thank you for any and all suggestions.
Wyman
Wyman 36A
05-20-2007 13:12:44
 Re: Dropped the Carb and broke it in reply to Wyman 36A, 05-18-2007 15:56:45
Thanks for all the help and advice. We welded it up with a nickel rod and it is back on the tractor. We pull started the tractor this morning. Still runs rough I have a lot of work to do on this one. Would probably be happier with something with electric start. Thanks again for all the help.
Wyman
P Browning
05-20-2007 14:36:02
 Re: Dropped the Carb and broke it in reply to Wyman 36A, 05-20-2007 13:12:44
Hi Wyman -- Perhaps you can do as my Dad did as he was getting up in age -- parked his 36-A on top of the hill. To start, he would open both the fuel valve(s) and petcocks, close choke, roll 'er over a time of two, open the choke back wide, then mount the tractor and let it roll down the hill to start! No pain!
This method isn't nearly as effective if you don't have a hill!! Have a Great one! (PatB)
F-I-T
05-19-2007 15:57:28
If you want to weld it and not braze it, you can do a great job as a first timer using Muggyweld rod and a stick welder. Muggy fills and grinds and finishes just like cast, and it's not so brutally hard as nickel which I find just too difficult to deal on cast itron repairs. A so pre-heat and a nice torch cool down is all you'll need. I either use cast iron ingot and my Henrob actylene torch, or Muggyweld. Muggyweld is by far the easiest to apply and to deal it down the road. If you feel ansty, get a few Muggy rods and take it to your local good welder if you like, let him run a bead or two on a piece of scrap cast iron manifold and then make your repair. I included a link to their site.
Frank
johns48jdb
05-19-2007 05:13:34
take a grinder and make a small "v" in the crack on both pieces, clamp both pieces down to a metal plate to help keep it flat and braze the side you can get to up and let cool. unclamp and braze the other side. i'd still carry it to a machine shop and have it check for flatness or even have it surface ground on a belt sander that is used to true heads and manifolds with.
Bob
05-18-2007 16:02:47
No "biggy". Braze or arc weld the ear back on with nickel rod. Then, grind it down, and fill any pits with epoxy. As the epoxy begins to set up, press coarse sandpaper against it to give it a sand-cast look. The repair will be all but unnoticeable.
JD@Antique Acres
05-18-2007 16:02:16
Yes it can be brazed back together, I have a couple like this myself. Just make sure that the surface is true after it is brazed other wise you could have an air leak.
Wyman 36A
05-18-2007 16:38:43
 Re: Dropped the Carb and broke it in reply to JD@Antique Acres, 05-18-2007 16:02:16
Could I use my Mig welder for this?
Mike M
05-18-2007 16:50:47
 Re: Dropped the Carb and broke it in reply to Wyman 36A, 05-18-2007 16:38:43
Brazing would make a real good repair. You can just make a whole new ear and redrill the hole.
You would need some kinda nickle wire I would guess as with a reg. welder you use nickle rod. This will take more heat than the braze and harder to control.
