Almost done. Carb Mag problems
txasylum
05-17-2007 19:36:31
My B is almost done. All that is left is to rebuild my DLTX67 carb and the mag. I have no experience with the mag, so this will be a learning experience.
As for the carb, I got the big nut off the bottom, but I can't get the bowl to seperate. Does anyone have any tricks to seperate the bowl?
As for the mag, I put a plug on the end and turned it over. It is clicking, but no spark. I decided to order an overhaul kit. Is there anything else I should know about the mag?
Yes, I do have the manual, but am looking for advice from experienced folks.
Thanks
Bob
Mike M
05-18-2007 04:35:02
 Re: Almost done. Carb Mag problems in reply to txasylum, 05-17-2007 19:36:31
Mark the position of the fuel bowl so that your fuel line hooks back up easy. A rap from a mallet should free it.
You may get spark back by just cleaning the points ? Not too much to a mag. Just don't try to clamp it in a vise by the body you will distort it and then bind up the rotor. and on the insides don't remove the funny screws holding the laminated sections in the housing.
P Browning
05-17-2007 21:45:43
This may be a great time to consider purchase of a video from Robert's carb Repair on overhauling the magneto -- assuming you are going to dig into it yourself. (PatB)
