STX46 STEERING WHEEL
BILL NOLAN
05-17-2007 18:57:35
HI I AM TRYING TO CHANGE THE THROTTLE CABLE AND NEED TO REMOVE TEH STERING WHEEL. THE LARGE PHILLIPS HEAD SCREW WILL NOT BUDGE -- AM I DOING SOMETHING WRONG? I REMOVED THE NUT ON THE OTHER END BUT CAN'T GET THE PHILLIPS TO BUDGE -- IS THERE A KEY HOLDING THE STEERING WHEEL ON? FRUSTRATED. THANKS FOR ANY ADVISE YOU CAN GIVE.
corey c
05-18-2007 13:50:30
 Re: STX46 STEERING WHEEL in reply to BILL NOLAN, 05-17-2007 18:57:35
Like mentioned before drive the bolt out. You will need to buy a new bolt. The steering wheels are a mother to get off. Sometimes the will break while trying to get them off.After getting the bolt out hold the steering shaft with pipe wrench and turn the steering wheel while holding pipe wrench. Lift the wheel while turning back and forth.
37ar
05-17-2007 19:24:39
drive it out with a pin punch from the threaded side.
