How to install PTO shaft seal
Scotty H
05-17-2007 09:36:08
I'm working on putting a new PTO shaft seal in my 45 A. Whats the easiest way to get the seal into the housing. The seal is pretty thin and chinsy. I dont have a seal driver but I guess I'll probobly end up buying one. Also I've heard that since the new seals are thinner than the old ones that you should put two seals in. Does this help or is one seal enough and does the second seal go in backwards. Thanks for any help.
Mike M
05-17-2007 11:22:11
 Re: How to install PTO shaft seal in reply to Scotty H, 05-17-2007 09:36:08
Forgot to add; Polish off the burrs on the shaft and use a shaft protector when installing the seals. I have an old microfiche card that works really well for protecting those seal lips. Wrap it around the shaft then slide the seals and housing on then pull out the card.
Mike M
05-17-2007 10:11:10
I'd put 2 seals in with the spring loaded lip to where the oil is. I have decent luck pressing in seals in my press and sometimes you can find a 3/4" socket to use for a driver.
F-I-T
05-17-2007 10:31:06
 Re: How to install PTO shaft seal in reply to Mike M, 05-17-2007 10:11:10
Mike:
It's been a number of years since I had an early styled "A" apart, but wouldn't it be a cheap safe guard for him to install the back side of the pump seals right now as well? If he cures a leak on the outside, I would be concerned that it might just start pushing past the internal seals back and into the rear end oil, and he'll ruin the gear lube and still have to go back in a couple of months. I'd appreciate your take.
Mike M
05-17-2007 11:17:53
 Re: How to install PTO shaft seal in reply to F-I-T, 05-17-2007 10:31:06
The A and B models didn't really have a problem with those inner seal unlike the models 50-730 that have a real problem with them. And the seal is a mechanical seal where I'm thinking a metal ring with packings in it and spring pressure rubs against a bushing. The outer PTO seal is really easy to get to at too. Just remove 3 bolts and pull off the seal housing.
F-I-T
05-17-2007 14:15:28
 Re: How to install PTO shaft seal in reply to Mike M, 05-17-2007 11:17:53
I know the 50/60/70-up had that problem for the most part because that inner seal was the only thing that separated the pto box oil from the pto lube pump which pushed and squeezed the lube into the rear end oil. Still, I was thinking that I just hate to be that close and not renew a seal.
Thanks.
