jdemaris
05-17-2007 11:14:03
Hey - 1010/2010 was an innovation (sort of) in reply to JDknut, 05-17-2007 09:46:29
I never heard any such thing as far as the sleeve-decks go. I worked on 1010s and 2010s when they were new, and followed things pretty closely over the years at several Deere dealerships I worked at. I'm not aware of any issues with the one-piece sleeve deck that the later single sleeves did not also have. The problem with any of them was the single and mono-material seal. The 1010 and 2010 sleeve-deck uses one black non-swelling seal per cylinder just as the next series engine did - e.g. in the 1020, 2020, 350 and 450 crawlers, etc. But . . . Deere came out with updated three-seal-per-sleeve kits for the later engines - yet never did with the 1010/2010s. The updated setup uses two standard black seals, but also the reactive orange seal that swells as soon as it contacts coolant or petroleum. 1010 and 2010s did suffer from many early parts getting discontinued - especially some fuel injection parts from Bendix. But, if cared for, the engines were not all that bad. In fact, I bought a 1010 crawler-loader from my neighbor last year. He bought it new in 1960 - gas engine. As of last year - it had NEVER been torn apart - the engine was still original. It caught fire - he couldn't affort to fix it, and I bought it. Although the fire was a relatively light one, the sleeves leaked coolant into the crankcase. I tore it down - reused the sleeve deck, put in new seals, and regrooved and shimmed the old pistons since the top ring grooves were worn. I also replaced all the bearings - even though the originals all still looked pretty good (and they were all dated 1960). Nobody knows how many hours the crawler had on it, but I DO know it was in use, every day or so except for winters, since 1960. That's pretty darn good - and - it didn't take much to bring the engine back to life - and I've been using it almost every day. In regard to price? Right now - a brand new sleeve deck for a gas 2010 or diesel 1010 (same sleeve part # AT15761) is $500 list-price from Deere. A new single sleeve for the later engine - list price is $91 - and you need four of them to compare to the older one-piece sleeve deck. So - you've got $500 versus $364. Certainly a difference, but not what I'd condider a huge one. I find it amazing that you can still buy a sleeve-deck from Deere for a machine built in 1960. An other problem associated with 1010/2010s is the lack of more competitive aftermarket parts - but . . . some places in China are now making some of the stuff. I will also add - that although there were many things wrong with the 1010/2010 series - there were also some very good things being tried for the first time. 1010/2010 was the first Deere diesel ever built using the "new" Vernon Roosa - i.e. "Roosamaster" rotary fuel injection pump. Cletrac beat Deere by a few years first using it in a Hercules diesel. Also - 1010 crawler was the first to use the new hydraulic reverser with Twin Disk internals - that was used sucessfully up through the 350 series -and maybe still is somewhere. Also - I believe - but wont' stake my life on it - that the 1010/2010 series is the first attempt by Deere to use a removeable sleeve system. And - in regard to BD's comment about the 1010 only being worth its scrap value with a wrong engine? I've been a scrapyard searcher for 50 years and found some pretty amazing stuff getting scrapped out. Even in the past 5 years, I've gotten complete running Cat D2s and D4s, Allis Chalmers HD3s, several Olivers and Cases (not running) - all for the price of scrap. But - I've never yet come across anything from Deere that went for scrap value. Maybe someone is throwing out Deere's buy you, but I've not seen it yet. And, used parts prices are going up all the time.
