4430 vs 4230
Lincoln
05-16-2007 20:15:34
I've been looking for a newer tractor. With the prices on 4020s going crazy I'm leaning toward either a 4430 or 4230. Are there any particular advantages to one or the other of these tractors? Also wondering what is the better of the two transmissions in these tractors.
Stonecreek
05-17-2007 11:46:33
 Re: 4430 vs 4230 in reply to Lincoln, 05-16-2007 20:15:34
The two are virtually identical except for the horsepower, which comes from the turbocharger on the 44. The 44 may also be equipped with larger tires than the 42, although many were the same. It varies with the part of the country in which they were sold. The 44 typically came with either 18.4x38 or 20.4x34, while the 42 would come with 18.4x34 or 18.4x38.
If you don't need the extra power, save yourself the complication of the turbo and get the 42. If you need more than 100 horses, the 44 is a good tractor. There's typically not much difference in price and either will sell according to its condition.
charlesmacleod
05-17-2007 00:36:15
I have both , an earlier 42 and a late 44 , I agree about the seat , the early seat is not high at the back and slippery (sweaty) plastic , the quad has 16 well spread gears rather than 8 with the powershift or syncro . 42 seems much quieter with a smaller exhaust outlet , and with only 100 hp compared with the 4630 on 150 hp must be very understressed .Later Bosch pump makes for much better starting but a miniscule sniff of ether always helps. 44 has lots more power and scope for further increases , but will no doubt have worked much harder in the past
Both are excellent and so much better than a 4020 for a long day's work early 44 s had a rear end which could be broken with abuse but it will have been upgraded by now if if was a problem
very simple tough tractors , give them regular filters and clean oil , good workers and future classics
R. John Johnson
05-16-2007 21:45:15
Depends on what you want to do with the tractor. Tillage? Haying? Definite advantages over the 4020. Quiet air conditioned cab, stronger front end, no 24 volt electrical system and more transmission choices. Quad Range is the old synchro with a high/low hydraulic shift and is preferred over the syncro. 4430 will have more horses than the 4020. Negatives will be increased fuel consumption(from what I have heard on this forum) and poorer cold weather starting. Longer wheelbase might make them a little less maneuverable. If you get a 30 series, replace the seat with a personal posture seat from a 40 series and it will be much more comfortable. I have a 4230 and use it to round bale and haul hay. I replaced the seat with a personal posture seat and put the pioneer barrels in the couple bodies. I've read it may be a better option to trade a wrecking yard for a coupler body from a 50 series.
My two cents
John
