855 PTO Disconnect
rfg1944
05-16-2007 13:23:42
I have an 1993 855 with a 60 inch mid mount mower. Need to take mower off and I cannot figure out how to disconnect pto shaft.
F-I-T
05-16-2007 16:05:09
 Re: 855 PTO Disconnect in reply to rfg1944, 05-16-2007 13:23:42
third party image
Hi rfg:
I have an 855 with belly mower. Do you mean remove from the tractor end? Because the mower end is held in place with a woodruff (half-moon) key and a spring pin. On the tractor end, there is a knurled ring that is held toward the tractor transission by light spring pressure. Just pull that ring away from the tractor transmission by hooking your fingers over it and the yoke, then while still holding it away from the tractor, slide the pto toward the mower and off the stub shaft.
Also included is a snag-it from the JDParts parts book page.
Frank
rfg1944
05-17-2007 05:34:45
 Re: 855 PTO Disconnect in reply to F-I-T, 05-16-2007 16:05:09
Thanks Frank exactly was I needed to know. Yes on the tractor end. Mower end is missing spring pin and previous owner had tied wire through it. Appreciate your help and I will get back at it this weekend and hopefully get it removed.
F-I-T
05-17-2007 08:08:21
 Re: 855 PTO Disconnect in reply to rfg1944, 05-17-2007 05:34:45
Let me know if you have any other questions about that tractor mower combination. I bought one in '94 at auction with 1500 hours on it, 955 sized turf tires, a serious electrical problem, and holes in the worn out deck. I told my daughter that it needed tires, a deck, and wiring and painting.
I just now put new tires on it, pathed the deck about 50 times (the new deck shell is on the shed waiting on me), the wiring was repaired immediately, and I plan on painting it this fall. I got 1,000 hours out of the bad tires and junk deck, so I am familiar with just about every seal, key, spring, and pulley on the thing.
The first thing that I did was to spend $100 on the parts and tech manuals for mower and tractor, and I have saved that price a dozen times over. If you need a reference out of the service or barts book let me know. The guy to benefit from that book was a fellow that checked in here from New Zealand with a brokenb 855, and we got him up and running, so see, we even fix Kiwi tractors!
rfg1944
05-17-2007 10:13:29
 Re: 855 PTO Disconnect in reply to F-I-T, 05-17-2007 08:08:21
Mine is a 93. Hour meter works and says 350 but big turf tires are original at about 55-60% so I don't believe the meter. Deck appears to be in really good shape no holes etc. Tractor was repainted by someone who obviously knew what they were doing so all in all I am pleased. I do however have a minor leak somewhere under the transmission which I have not bothered to track down. It can sit for a week and maybe lose half a teaspoon so not a major problem, but on concrete half a teaspoon looks like a quart. I always check it before starting anyway. Other than a tear in the seat that is all I can find wrong. I just had the rod break that holds the belt tensioner to the spring and got a new one and thought I better get an extra belt. Man alive the price was $57 and change from local dealer but what are you going to do so I paid up. Good luck on getting everything done on yours but since you have the manuals I am sure all will go well. I also have an X595 with 54 inch deck that is not as heavy as the 855 but very nice running machine that I really like. Because of its size and turning radius it will mow circles around the 855 but I have projects I need the extra weight of the 855.
F-I-T
05-17-2007 10:36:32
 Re: 855 PTO Disconnect in reply to rfg1944, 05-17-2007 10:13:29
I think in the future I will go to a front mount z-turn style machine for mowing only, and move up to 4WD and about 40 horse for the loader tractor. Then again, I am looking for a 4020 PS to restore for that purpose, though that woul.d be overkill. With sharp blades and cool grass, that 855 cover some ground in this, sandy, Florida turf I have.
