early 4020 ground
5020s rock
05-16-2007 12:30:19
hi ole great john deere legends.-- i have
a 64 4020 gas, i seem to remember a discussion
on here that revealed these tractors have a positive ground? if so, did all of them have it
or just some? how can i tell? thanks
5020s rock
05-17-2007 01:09:57
 Re: early 4020 ground in reply to 5020s rock, 05-16-2007 12:30:19
hi--thank you, i will check it out.
Gerald J.
05-16-2007 14:56:03
My 4020 books (shop manual, I&T, etc) all say the early gas 4020 was positive ground. Mine is now negative ground with an alternator. Had to change the polarity of the ignition coil too as well as the ammeter that I added.
Gerald J.
G/MAN
05-16-2007 13:30:30
It should be positive ground, if the electrical system hasn't been "re-engineered" at some point. Look at the battery posts and cables. If the cable on the positive post is bolted to the tractor chassis and not the starter, it's still positive ground.
