Deere 420 different pto shaft lengths
Bill420U
05-16-2007 07:28:33
I have a 1956 JD 420U with which I want to run a 3pt rototiller off the pto but I find that my pto shaft is too long. Checking the Parts Catalog PC-505CC in section 30, pages 44-45, I see that there two choices of powershafts of which one M2745T is for models U and H and the other M2916T is for models C, I and W.
M2916T is just under 10 inches (9 15/16) and M2745T looks to be about double that length. Why the two sizes? Was the 420U pto designed for pulled implements only?
Complicating the matter is the fact that the 420 does not have independent pto so to prevent breaking it while utilizing a bush hog, it is recommended to install an overriding pto coupler which I did but that adds almost 4 more inches to the pto length.
I guess I have to find a M2916T as well as the M2915T housing if I�m going to operate 3pt pto driven equipment.
Has anybody experienced this problem? Does anybody know why the two different lengths?
Bill
MLD
05-17-2007 07:42:34
 Re: Deere 420 different pto shaft lengths in reply to Bill420U, 05-16-2007 07:28:33
On my 40 you couldn't raise the bushhog because the pto shaft was too long. I used a sawsall to cut about 4" off the inner & outer shaft. I've never tried to run a tiller??
jCarroll
05-17-2007 06:03:32
This is not what you want to hear, however ..... ..... .
Shorten the tiller PTO shaft to fit your existing PTO stub. You do not need the over-running clutch on the tiller.
The tractor without live PTO will be borderline when tilling. You will want to advance slowly at times to let the tiller do its work - and pushing in the clutch will stop the tiller. If you have a small patch, you can make it work, but it won't be fun.
The different stub lengths are to accomodate the different rear ends on the U and the W. ASAE specs give the dimensions of the lift arms, and the PTO shaft location, and JD was designing to those specs.
Henry M
05-16-2007 16:48:34
Here is the expensive option. Trade for one with live pto, it came out in 58. Just kidding.
My five speed in low is pretty slow, but I still would think it would be too high for tilling.
I donno.
Surely you can find a way to shorten the shaft on the implement.
bill420u
05-17-2007 05:58:10
 Re: Deere 420 different pto shaft lengths in reply to Henry M, 05-16-2007 16:48:34
I agree that a 420 would move too fast to properly till the ground especially if the soil has not been plowed previously. I used a 1986 JD 750 to do the tilling and had to run it in low low. (It has a 2 speed rear). This land has not been plowed since the 1950s. At first, when I tried to till it, it did a poor job. Only after I plowed the ground with a 2 bottom, did the tilling work well.
I do want to use the 420U to handle mowing so either replace the pto shaft length or use implements with shorter shafts.
Hayfarmer
05-16-2007 07:41:44
I have a 430 with the longer shaft and housing. I think the shaft length probably was determined by the drawbar and support setup on the tractor. Mine is a 430 U. A neighbor has a 320U with the same type PTO as mine. I have run into the same problem when using a brush hog with the overriding clutch. I just shortened the PTO shaft on the hog. I suppose you could look for a shorter shaft and housing. They show up some on e bay, seems like more than the longer one. It is easy to change, you need to remove the pto and housing once in a while to fill it with oil anyway.
