4020 Rockshaft Control (out of Time?)
MRN
05-15-2007 20:28:52
I reinstalled the rockshaft housing on my low serial number 4020 and now the control valave operating mechanism control lever is about 90degrees out of time (the three point hitch goes up, but only when the operating lever arm on the rockshaft housing is pointed towards the front of the tractor and approx. parallel to the ground). How do I adjust this? Is the arm threaded in the bearing quill, can I unscrew the arm and reset it that way or do I have to remove the rockshaft housing and adjust internally?
Gerald J.
05-16-2007 10:40:08
 Re: 4020 Rockshaft Control (out of Time?) in reply to MRN, 05-15-2007 20:28:52
It likely depends on which vintage 4020 you have, side console could be drastically different than pre side console.
I know in the pre side console that the three point control shaft runs a split gear that if turned too far will let loose of racks and get out of time. Takes the shop manual to get it working again.
Gerald J.
dwag
05-16-2007 10:37:17
Sounds like the draft signal arm did not go into its proper place when housing was set on. You might be able to see it if you remove hyd oil filler pipe.
G/MAN
05-16-2007 07:46:32
Sounds like something is out of whack, because normally that arm is under spring tension, pointed toward the back and has to be pulled up in order to get the arm connected to it. It's been a while since I've worked on one, but what you're describing doesn't sound right. There is an entire adjustment procedure that should be followed to properly set the rockshaft whenever the housing is removed, the rockshaft valve is serviced or the load shaft is serviced.
