1640 Hydraulic Trouble
Modlegend02
05-15-2007 14:25:22
Hi a friend of mine has a 1640 that the hydraulics for the loader dont work properly. You have to keep the throttle reved up a little to get anything to work. The pump is not worn because at time it works perfectly. The 3 point hitch will not stop going up or down it"s like the valve in the top of the trans. is bypassing & stealing pressure from the loader. When the tractor is not working properly and you try to lift the bucket the hitch goes down????? Any help would be Great Thanks.
Tx Jim
05-16-2007 04:03:23
 Re: 1640 Hydraulic Trouble in reply to Modlegend02, 05-15-2007 14:25:22
More than likely it has an internal hi-pressure leak. Probably in the rockshaft control valve or steering. Take hyd oil filler cap off with engine running,3pt in up position and look in hole for spraying/misting oil. Also if loader has independant hyd valve some are convertible from open to closed-center and the plug that converts valve can blow an o-ring. Tx Jim
