4020 hydralics control valve?
skooby
05-14-2007 18:21:35
I have a john deere 4020. the hydralics quit working. when I flip the levers on the qwik couplers oil is pumping out even though the control levers are in neutral. when hooked to cylinder the hose jump but it will not move cylinder. any help?
Gerald J.
05-15-2007 09:41:27
 Re: 4020 hydralics control valve? in reply to skooby, 05-14-2007 18:21:35
There is an information gap here. We need to know which 4020 you have. There is a world of difference between the hydraulic valves of the early and the late 4020 (side console). The only thing they have in common are the Deere mating hose fitting, the green paint and the Deere name. They are totally different construction with totally different failure modes.
Gerald J.
skooby
05-15-2007 16:33:14
 Re: 4020 hydralics control valve? in reply to Gerald J., 05-15-2007 09:41:27
thanx for info 4020 is a 65
Tx Jim
05-15-2007 04:34:39
Sounds as if the rockers inside the SCV valve body are mal-functioning or detent roller is stuck or broken. Dependig which way you plug-in couplers you have two poppet valves on up and two poppet valves on down pressure,each of which one valve is pressure and one is return. JD's SCV's are a little trying to repair so I suggest you get a tech. manual or take it to a qualified mechanic. Tx Jim
Stonecreek
05-14-2007 20:01:33
Your valve(s) is stuck in the forward (toward the front of the tractor) or "in use" position. This happens with a build up of oil and dirt. You need to tap them rearward (outward) from behind (again, toward the front of the tractor) in order to return them to the "closed" (not in use) position. Blast them off good with an air gun, or even with high pressure water, then move them in and out (attaching and detaching a male hose end) until they are clean and operating freely.
There used to be an aftermarket lever apparatus you could mount that would push the valve recepticals outward to facilitate proper operation.
