JD 4020 gas 3pt
Jake in North D
05-14-2007 08:43:51
My 3pt won't work. I have a slow hydraulic leak and the lever on the dash won't budge. I'm not a mechanic but I have a shop manual. Where should I start?
Bob
05-14-2007 08:52:50
 Re: JD 4020 gas 3pt in reply to Jake in North Dakota, 05-14-2007 08:43:51
Unstick or replace the Morse cable from the three-point lever down to the valve.
Where's the hydraulic leak?
05-14-2007 10:09:21
 Re: JD 4020 gas 3pt in reply to Bob, 05-14-2007 08:52:50
The leak seemds to be high on the right side of the tractor under the floor plate. Getting to it has been a problem because of the loader. It's an F-11 farmhand loader with welded braces that extend across the floor plate.
Bob
05-14-2007 10:18:08
 Re: JD 4020 gas 3pt in reply to Jake in North Dakota, 05-14-2007 10:09:21
The steel lines to the rear hydraulic couplers pass through there, and often get holes rusted in them from the chaff, dirt, mud, and debris that builds up under there.
The Morse cable to the three-point passes though that area, too. Do you see a pattern developing here?
05-14-2007 12:06:21
 Re: JD 4020 gas 3pt in reply to Bob, 05-14-2007 10:18:08
Yep, I think I need to get in there. Thanks Bob
Gerald J.
05-14-2007 12:17:31
 Re: JD 4020 gas 3pt in reply to Jake in North Dakota, 05-14-2007 12:06:21
Been there done that. Be sure to observe how the ends of the cable are anchored so you get it back right.
Gerald J.
