B thermostat
teddy52food
05-14-2007 06:21:08
Some time ago, I asked about putting a stat in my B. Well I did it. Made a plate to go between the block & water pipe with a hole for the stat. Held it in with 2 screws & washers. Also drilled 2 3/8 holes so the coolant can flow to warm the stat. Went for a drive on Saturday & all is well. Temp gets up between 160 & 180 just pattzing around.
Ford 312
05-14-2007 07:04:31
 Re: B thermostat in reply to teddy52food, 05-14-2007 06:21:08
I would like to see pictures of your project. Also, what kind of thermostat did you use? I am curious how the thermostat will work when tractor is working with a heavy load. A thermostat would be a big improvement in helping with faster warmup. Thanks, Don
teddy52food
05-14-2007 10:25:49
 Re: B thermostat in reply to Ford 312, 05-14-2007 07:04:31
I used a large diameter 195 stat. I think they fit the older Chrysler 383 & 440 engines. I don't think it opens just driving without a load. Sometime I'll try to get a good load for alonger time & see if it still cools enough. The temp bulb is above the stat & I think the coolant is coming through the holes enough to circulate with a lite load. I used a piece of 1/8 inch flat sheet iron. Sorry but I don't know how to post pictures. You have to look hard to see it anyway.
