JD 2010 PTO Clutch adjustment
G. Branson
05-14-2007 04:22:49
This tractor, made in 1962, has what seems to be the common problem of grinding gear noise when engaging the PTO. I have tried the "slow, smooth" push of the handle technique and it really does not help. I am assuming that the pto clutch is out of adjustment.
Can someone give me more direction about the inspection plate to remove for this adjustment. Facing the rear of the tractor I have looked "above and to the left of the drawbar" and see nothing that really looks like an inspection plate. What am I looking for?
msb
05-14-2007 20:24:50
 Re: JD 2010 PTO Clutch adjustment in reply to G. Branson, 05-14-2007 04:22:49
Don't do the slow and easy.Do the smooth and quick. That pto clutch is unlike anything you have probably seen before. As you push the lever forward, it momentarily engages a clutch disk just long enough to bring both shafts up to the same speed and long enough for a collar to engage the engine driven shaft which locks the shaft together.
G. Branson
05-15-2007 04:28:23
 Re: JD 2010 PTO Clutch adjustment in reply to msb, 05-14-2007 20:24:50
Thanks for the info. I adjusted the clutch yesterday and it works a lot better. It still grinds some. I understand what you mean about "quick". I think it's best to just push the lever on into gear.
