410 clutch vs tranny pump
eflynn53
05-13-2007 17:15:47
Looking for more 410 help..In the process of doing either a clutch or tranny pump and I was hoping someone could offer advice. When I finally get machine split and figure out what is wrong (clutch or pump)do I change the other part now too??? What would the mechanics that post here do???? Also, does deere offer reman pumps or only new??
matthies
05-13-2007 17:40:39
 Re: 410 clutch vs tranny pump in reply to eflynn53, 05-13-2007 17:15:47
Why do you want/need to replace these parts for? Whats your tractor doing or not doing? Just worked on a 410 that wouldn't pull itself sometimes, and found the clutch linkage binding up and limiting the clutch pressure for the reverser. chris
em53
05-17-2007 10:56:24
 Re: 410 clutch vs tranny pump in reply to matthies, 05-13-2007 17:40:39
Backhoe has no hyd at either hoe or loader. Also have no tranny. Checked press relief valves, clutch linkage etc. Finally ran it with no trans filter and have no flow at all at filter. At this point assuming it is either clutch or tranny pump.
