JD 60 high/low problem
Dominic Centonz
05-13-2007 04:09:39
Mechanics---please help. I cannot shift my JD 60 from high to low range, or low to high while the tractor is running. It just grinds. If the engine is not running, it easily shifts. How can I fix this? My sincere appreciation to my respondants.
dds-inc
05-13-2007 20:11:01
 Re: JD 60 high/low problem in reply to Dominic Centonze, 05-13-2007 04:09:39
sir, pleassssseeeee e get an operators manual.....you are apparently grinding gears with the clutch engaged or playing with the power take off lever!!! stop what you are doing and save lives!!!!! !!
HAPPY DEERE
05-13-2007 16:21:50
ever since the super late a's were introduced they had a sigle stick transmission first off the only thing you can be doing is trying to disengage the pto next you need to get of the tractor and get a opertator manual and read it and figure out where it goes then ask all the questions you can till you learn how to safely run it
exactly what it is suppos
05-13-2007 11:55:07
that's exactly what it should do!! the other posts are right on.
BLinWMi
05-13-2007 04:50:23
You need to get a manual for the tractor, because the JD 60 never had a high low tranny, the 70 did but the 60 row crop or standard did not. the only lever on the right side of the shifter quadrant is to disengage the pto from the engine.
Mike M
05-13-2007 04:44:46
Disengage the clutch and adjust the pulley brake so you can stop the pulley from turning ?
Or is it the live pto lever by your right toe you are confusing with a high/low as the only high/low on a 60 happens when you shift from one side of the quadrant to the other. This pto lever MUST have the engine off while shifting.
