Tire preservation?
two cylinders s
05-12-2007 20:24:26
Hey guys , got a quick question, i was wondering what you guys put on your tires to prevent dry rot if this is possible? I'm talking on tractors stored inside with them being in storage 90 % of the time. I"m assuming they make something to keep moisture in the rubber ?
James22
05-13-2007 17:01:56
 Re: Tire preservation? in reply to two cylinders saves gas , 05-12-2007 20:24:26
Somewhere I believe that an article said that using glycerin would soften the tires and keep them from cracking. I have a couple of small splits on my large combine tires and have been "dabbing" the splits with glycerin to see if it will help keep them from spreading.
JD@Antique Acres
05-13-2007 08:50:46
Keeping them out of the sun will go a long way, as this does more damage than anything. As mentioned Armorall will make them look pretty, but unless constantly applied I don't believe it will keep them from cracking.
Randy G.
05-13-2007 05:11:13
I put nothing on mine. I put new tires on my 49 B in 1983 and have no crack at all. I too keep them all inside all the time. Armorall would be my first choice if I did use something.
