JD 544b 300 series engine
Codyrsmit
05-11-2007 13:09:38
i just wanted to know if any one can tell me the head bolt torque specs and the valve lash and the timeng mark? if any one could tell me
I'd be...
05-11-2007 16:34:34
 Re: JD 544b 300 series engine in reply to Codyrsmit , 05-11-2007 13:09:38
looking for a head bolt torquing diagram too.
Codyrsmit
05-12-2007 08:40:48
 Re: JD 544b 300 series engine in reply to I'd be..., 05-11-2007 16:34:34
yeah u got one?
In a
05-14-2007 13:27:59
 Re: JD 544b 300 series engine in reply to Codyrsmit, 05-12-2007 08:40:48
service manual.
HTR
05-11-2007 15:54:06
The head bolt torque depends on which bolts you have. The old style bolts with flat washers, I think is 110 ft lb. If the loader is new enough to have the new style flanged-head bolts, or has been updated to the new bolts, the torque is, 110 ft lb plus 60�. This is done in three steps.
Pump timing is, number one TDC on compression stroke, and timing pin in hole of flywheel, pump marks lined up.
720 in pa
05-11-2007 13:40:52
110 ft lbs. head bolts
.014 intake
.018 exhaust
Codyrsmit
05-11-2007 14:56:43
 Re: JD 544b 300 series engine in reply to 720 in pa, 05-11-2007 13:40:52
would u happen to know what the timing mark is to be set to?
G/MAN
05-11-2007 13:30:44
Get the engine model number and serial number and go to a Deere dealership to get the proper service info. Why would someone pull a cylinder head without a manual?
