420 lost power?
TwoCylinderDiesel
05-11-2007 10:01:31
After working perfectly for years, my 420 suddenly lost all it's umph. It will barely go in 3rd gear. I checked the compression, both cylinders at 120PSI when cranking. Replaced the points and checked the timing as I know from experience with my MC that is usually the issue.
Starts just fine, doesn't smoke, just has no power to do anything. Any hints?
P Browning
05-11-2007 15:09:01
 Re: 420 lost power? in reply to TwoCylinderDiesel, 05-11-2007 10:01:31
Fuel, compression and spark at the right time -- you would expect the engine to operate normally. Other responders have covered the waterfront -- but as I was scanning the forum, a question hit me -- is this engine getting sufficient flow of input air?
See the space between these parens ( ). That's how much experience I have with a JD-420. But it can't hurt for you to separate the air inlet piece from the carburetor and see if you note a difference in performance. If so, then you need to troubleshoot AIR-IN. (PatB)
95CS
05-11-2007 13:01:07
Make sure the advance plate in the distributor is loose and able to move. A stuck advance plate will make a real dog out of an otherwise good-running tractor.
buickanddeere
05-11-2007 12:38:41
Take both plugs and hurl them as far as possible. Replace with Autolite 216 or the hotter 437.
TwoCylinderDiesel
05-11-2007 10:18:53
I replaced both the points and condenser. Pulled the plugs and both have nice bright blue spark. Tried pulling the plug at the bottom on the carb, had to poke a screwdriver up there and then a nice stream of gas flowed through. Am thinking it is a carb issue as I have power for a bit, then it rapidly loses it.
CPeter
05-11-2007 10:07:18
Try the fuel flow test. You should have a pencil sized flow from the drain plug on the bottom of the carb with the plug removed. If not start looking for the blockage. One place not to miss is the screen on the inlet elbow. Also the nipple on the filter bowl that goes up into the tank will collect rust and scales and clog. Been there, done that and got a couple of tee shirts. This sounds exactly like a 420 that I have. Chased the problem for years and finally found the nipple plugged. On a second one, the elbow screen was completely clogged with varnish.
CPeter
TwoCylinderDiesel
05-11-2007 10:23:46
 Re: 420 lost power? in reply to CPeter, 05-11-2007 10:07:18
Is the carb adjustment the same as on other deeres? Turn the needle in until it looses power, then out until it runs smooth and add 1/2 turn?
Mike M
05-11-2007 11:21:41
 Re: 420 lost power? in reply to TwoCylinderDiesel, 05-11-2007 10:23:46
Pretty much that's how you do it,but on the load needle your going to need it under a load to do it that way. You may need to unscrew it farther if just running wide open with no load so it has more fuel when the load is there. The main thing right now is to see if you can back it out enough to make it smoke black to show it has too much fuel and the adjustment isn't plugged up.Then screw it in enough to clear up and still pull the load.
Mike M
05-11-2007 10:06:33
Have you tried adjusting the carb. load needle to see if it makes a difference ?
You put in new points but not a condenser ? Condensers can do some funny stuff.
CPeter
05-11-2007 10:08:29
 Re: 420 lost power? in reply to Mike M, 05-11-2007 10:06:33
Don't throw the old condenser away. Sometimes the new ones are worse than the old.
CPeter
Mike M
05-11-2007 10:13:01
 Re: 420 lost power? in reply to CPeter, 05-11-2007 10:08:29
Yes that can be very true. I've been there and done that one also. I've had several condensers "screw" with me,new and old.Just hard to get good parts .
