6 volt to 12 volt conversion
txasylum
05-11-2007 07:31:44
What does it take to convert a B from 6 volt to 12 volt? I assume a new batter and alternator/regulator. Anything else?
Bob
John T
05-11-2007 09:05:23
 Re: 6 volt to 12 volt conversion in reply to txasylum, 05-11-2007 07:31:44
First decide if you wanna stay as original using a 12 volt generator at Positive ground or convert to a Negative ground alternator and what kind??? If you stay with a genny (new or used or rebuilt or have your 6 volt converted to 12) and Positive ground all you gotta do (if its battery powered coil ignition, NO changes to ignition required if a Magneto) is EITHER add an external series voltage dropping (12 to 6) Ballast Resistor after the ignition switch and before the old 6 volt coil OR ELSE buy a new full true 12 volt rated coil no external ballast required.
OF COURSE, you would also need a 12 volt Voltage Regulator if you go the 12 volt genny route.
Change any lights to 12 volts.
Hook up the 12 volt battery (original was positive ground) n polarize the genny (if you use a genny) and a light change gets you going.
If you use an alternator and have to convert to negative ground then you gotta swap coil (if a coil ignition) n ammeter leads.
Post back what you decide n we will tell you more.
John T
720 in pa
05-11-2007 08:51:04
new battery and on my tractor i had the generator rebuilt and switched to 12 volt.always thought it dont look right with an alternator on a b.just my personal view.also put a 12 volt regulator on it,and didnt do anything with the starter
