jd350 reverser problem
AndyJd350
05-11-2007 06:46:29
Hi my 1967 jd350 has stopped going forward, or rather does so but with no power, however reverse works fine.
I was wondering what the forum"s wisdom is regarding the possible cause - I expect it"s the forward clutch that"s worn out but could it be some adjustment that"s do-able without dropping the reverser out ?
Thanks
Roy Suomi
05-11-2007 13:34:47
 Re: jd350 reverser problem in reply to AndyJd350, 05-11-2007 06:46:29
Sorry , but it doesn't sound promising...Sealing rings on manifold , gasket blown on control valve , or clutchpack slipping..You can verify it by putting a gauge into the reverser control valve.. [ straight up vertical] 1/8 pipe plug on top of reverser control valve housing...Trans in neutral , run the reverser control lever forward and reverse at about 1/2 throttle..Should read around 135 lbs..
andyjd350
05-11-2007 13:59:41
 Re: jd350 reverser problem in reply to Roy Suomi, 05-11-2007 13:34:47
Thanks Roy good to see you are still on the board offering your great advice, I'm getting along by using the reverse gear to go forward, I'll try and get a gauge etc. but meantime am I risking doing damage running it as it is ?
Also out of interest - the foot clutch used to engage/disengage the drive - is that in effect one of the two clutch packs in the reverser ?
It went shortly after busting out some tough clay
so that might also point to clutch pack gone, but could of course be co-incidence too.
Cheers
jdemaris
05-12-2007 05:24:49
 Re: jd350 reverser problem in reply to andyjd350, 05-11-2007 13:59:41
Foot clutch cuts off all hydraulic power - forward and reverse.
