JD 40 rebuild/restore questions . . .
Matt Burkhart
05-10-2007 16:59:40
Hi All, I am rebuilding/restoring a 40-U in stages as I have the funds and had a few questions. What color does the carb and manifold get painted? Mine is bare metal right now. Green, high-temp black or another? A good picture of that side of a 40 would help. Does anybody have a picture of the lights and mounting. Mine is missing anything to do with the front/rear lamps. Lastly, what are the correct colors/styles for the breathers, fuel and rad. caps? Thanks in advance!
buickanddeere
05-11-2007 12:44:13
 Re: JD 40 rebuild/restore questions . . . in reply to Matt Burkhart, 05-10-2007 16:59:40
Don't know if Robert's Carb does reground cams for Dubuques or not. In any case the cam & followers should be at least trued up. For high altitude there maybe something that could be done with the lift & duration. Of course port matching, grinding rough edges from inside the valve bowls a 5 angle valve job should increase flow. Compression could likely be upped to at least 8 to 1 from the factory 6.5 or so to 1. Maybe better to just accept operation in a slower gear. Or look at purchasing a 420/430.
Maark
05-10-2007 18:09:42
carb and manifold as well as the breather cap, starter, gen.were originally green. The fuel cap and radiator cap were cadmium plated{silver}. More info at www.jd40.com
